    • #15376
      Mark lindsay
      Hi bike runs ok apart from recently has started to stall when at a stop at lights when bike sitting on idle seems only stall when engine is hot what can I do to fix the problem?
    • #15381
      When the engine is hot , can you do a compression test to confirm what it says on each cylinder with both plugs out and full throttle
      Ill have better advise after compression results.
