Viewing 3 reply threads
    • #7705
      Sam
      Bike runs great but when I pull clutch lever and put into first gear it kills the bike have tested side stand switch and clutch lever switch and all seems to be working fine currently chain is of bike waiting for replacement to arrive.When I engage 1st gear front sprocket turns abit before stalling I’m guessing bike would lurch forward if chain was on before stalling any ideas thanks
    • #7718
      Simon
      There can really only be a couple of things 1 the side stand switch easy to check just unplug it & bridge the connection 2 there’s something wrong in the gearbox I hope not, without a chain on it it would rotate even if it had a stuck clutch.
      • #7720
        Sam
        Thanks simon got it sorted it was a broken wire at side stand switch after all thankfully alls good now thanks for the advice
    • #8247
      Cobra2
      Side-stand switch seems to be a common trouble-maker.  And I often read advice to cut wires and permanently solder the ends together.
      But, having read stories about accidents…where side-stand was forgotten…I just wanted to make a reminder-light.
      This circuit on picture should work…if switch works… and will not interfere with ignition-system…
    • #8280
      Nice input, i also have a carby GV bike and its harness does not check for clutch switch (incase someone tries to start bike in gear) and no side stand switch connector , this is factory , nothing was cut. It seems later models of GV Korea did not bother adding extra checks thats why the later model of GV carby have 2 plugs for CDI
      GT has 3 plugs. I won’t like i did make a mistake many years ago setting off the bike with the stand down lol, i made sure this time i will never forget to check side stand is up before going away.
