Viewing 2 reply threads
    • #14539
      Cass
      Hi guys,
      I just bought a brand new battery for my decidedly not brand new gt650r as it was showing signs of giving out. I was able to install it without much trouble however now when I turn the key there is no sign of power at all. No lights, fuel pump, lcd screen, indicators or anything at all. I know the harness is good as it ran a few weeks ago with a push start, even the old flat battery could prime the fuel pump. I am completely stumped as to what i did wrong or how to go about fixing it, so any insight would be super helpful.
      (Yes I’m sure the terminals are the right way around)
    • #14544
      Simon
      Check the main fuse just a quick arc will blow it
    • #14547
      As per Simon.
      And also check under the radiator for the ignition plug , incase of corroded terminals going up to the ignition key.
