    • #3095
      Sam
      1. Hi there I have got a 2016 gt125r and the bike has a battery drain somewhere any ideas, new battery had it running for about 20mins end can still touchable turned it off came back to it battery flat no neutral light( intermittent) Speedo Digi Jos to like 70 then drops again buzzing noise coming from the back when hitting electric start
    • #3103
      Hey,
      The problem you describe is very commonly 2 things at play here:
      –  Battery is too small (life is shortened) – It must be size 12-14AH (Yuasa YTX 14BS is good)
      – Regulator = All hyosung branded regulators use the old “diode” tech (1970s), so once they get hot , they start to die rapidly which is annoying. It is probably #2 most annoying device after the side stand switch, but i digress lol!
      We use proper upgraded ones from Kawasaki  (hit “Shop” at the top menu to see what it looks like)
      When the above ^ is changed over.  Keep a good eye on your Stator (genenerator on the left side of engine casing , next to sprocket cover) it gets quite hot (more than the old gen) ,  it should be doing 75v-99v healthy if you’re handy with the meter to test it.
      All charging & ignition starts from this hot device  before it  tells your regulator to charge your battery  & your cdi to send sparking energy to the spark plugs to fire harder. =  So all these are kind of intermarried!
      If the the bits above ^ are sorted.  And you still hear some buzzing sounds or clicking noises when you press “START” ,   change the solenoid (common) it is that ball next to the battery ,  it controls starter motor.   If starter spins slowly  (battery & solenoid are the culprits generally)
      Sometimes the RC dash will flicker or spaz out all over the place when Key is ON or  START is pressed.
      Hope that helps.
