    • #13031
      Graham Walker
      having problems with lack of fuel at +9000 rpm. fitted larger filter and fuel lines to carburettors. the fuel level in filter very low and fuel into filter seams slow and remains low in filter. any suggestions appreciated.
    • #13040
      It could be the fuel pump ?  How old is it ? or total miles thise bike has done ?
      You can open the fuel pump and gentley clean it with carb cleaner and also check your air filter  (if its dirty) , the intake may be “choking”
      Also open your fuel tank key cap
      Look at the side , there is a HOLE ,  it is a “vent” hole , and it is also breather , thats why the fuel tank has an extra pipe that is facing the road.
      Or the fuel cap is faulty causing the air inside the tank not to vent off properly  (thats why the fuel cap has springs and rubber gasket on it.
