Viewing 5 reply threads
    • #13434
      Jim
       GT 250 snapped my throttle cable 32.7 miles from home. Lots of tight twisties, hills to get home. That was a little “too fun”.  I hope Marcel has a proper cable for me!
    • #13436
      Jim
      • #13443
        LaserBeam
        Did you apply throttle with a pair of pliers all the way home? Nice work. That’s not much fun.
        My throttle cable rotates under the handlebar switch (at the curved metal piece, infornt of your pliers). It’s probably normal but mine gets stuck with the bend pointing to the front of bike. When i turn right at near full-lock, it pulls the cable tight around the right fork, the throttle opens up & starts revving it’s head off, when i’m trying to do slow, tight turns. That’s no fun either. 🙂
    • #13437
      That doesn’t look too good!  – I got your email,  just waiting for your reply.  Someone just bought one the same time as you on ebay ? lol – I hope its you!
    • #13447
      Jim
      Did you apply throttle with a pair of pliers all the way home? Nice work. That’s not much fun. My throttle cable rotates under the handlebar switch (at the curved metal piece, infornt of your pliers). It’s probably normal but mine gets stuck with the bend pointing to the front of bike. When i turn right at near full-lock, it pulls the cable tight around the right fork, the throttle opens up & starts revving it’s head off, when i’m trying to do slow, tight turns. That’s no fun either. 🙂
      Yes, I had to use the pliers all the way to apply throttle. Thanks.  I think in your case, maybe you need to look at rerouting your cable. That is not great with your climbing revs!
    • #13619
      Jim
      Marcel got me fixed up ! Thank you!
    • #13639
      You are welcome!
