Forums 🚦 HYOSUNG CULTURE 😃 General Chat Setting headlight for MOT Reply To: Setting headlight for MOT
On the GTR, there is 2x adjusters behind the headlight box. Its done gently with a thumb screw , as they break off easy
This website says your MOT garage will need a specialist equipment to check aim is right, some old bikes sit high , some old bikes sit low, there isn’t a proper universal rule now no thanks to GOV change rules as they see fit. I’m not an MOT Tester , but i just fix bikes and the MOT guys check what i do before customer gets his bike back 😉
However, generally , the korean’s set the aim just fine and we don’t tend to touch it again , unless last owner was fiddling about.
