Forums 🚥 PiT STOP 🔧 Hyosung Technical Help GV250 Won’t run after carbs serviced! Reply To: GV250 Won’t run after carbs serviced!
Oh dear! Marcel, I am despondent! I am back to running on rear cylinder only. I felt sure the bike would run, even with the front carb starting jet blocked with a broken off needle tip (!!), but it seems it won’t. I have a spark, but only running rear pot. Can you find me a front carb body or suggest anything else I can try. I will send you pics of carbs via email. I have all the new jets already, so can fit them to a body. Hope you can help.
No rush fella, I will try to “hunt” down a carb body but due to scarcity they aint cheap anymore even 2nd hand, so expect to spend 3 figures yikes.
I pray its still possible to save yours.
