Forums 🚥 PiT STOP 🔧 Hyosung Technical Help 2013 gt250R F1 light on , bike not starting Reply To: 2013 gt250R F1 light on , bike not starting
Feb 27, 2023 at 9:33 PM
#9761
Do you hear the Fuel Pump under the time priming?
Is there a red Fi light on the dash too ?
Also check & swap relays around, sometimes if one of the 3 or 4 relays behind the seat panels blows out, the bike then doesn’t activate anymore.
Also check these
- Clutch Handle Bar Switch
- Side Stand Switch
- Connection to the ECU is very clean and there is not 1 single loose one (1 single loose wire can throw everything off)
Does it say F-1 or Fi (Fi is fuel injection system) (including what i said about the pump above ^ )
