Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Help finding carbs for gv250 Reply To: Help finding carbs for gv250
Feb 18, 2023 at 8:50 PM
#9681
Can we see any pictures of it ?> and what damage is on it ? It should be possible to still save them!
Also Korea has “made sure” their engines run perfectly with the carbs they intended for , so sky is the limit if you try to use other branded carbs but also engine wants “twin” carbs , and there is the issue of
- Airbox accepting other carbs (Hyosung’s hate pod filters and will force you to use the airbox back)
- Intake manifold were designed in a way they expect the original carbs to sit on them.
