Callum Hutchinson
  • Topics: 11
You can heat up that area a bit since heat causes metal to expand slightly and soak in some old bike oil between the pipe and the reducer, so you want the walls to slip up and pull it out.
in the end with penetrating oil, angle grinder and 3 hours, it’s finally out….. turns out they used JB weld the b****ds.
