Forums 🚥 PiT STOP 🔧 Hyosung Technical Help GV250 Won’t run after carbs serviced! Reply To: GV250 Won’t run after carbs serviced!
Jan 12, 2023 at 4:57 PM
#9432
Hi Alan, thanks. What are the Needle Sliders though? If they are the Needle Jets, I have new ones with the needles. Happy riding!
Hi Mike, this is the link to the tutorial https://hyoriders.club/forums/topic/tutorial-carb-slide-needle-tuning-hyosung/
- It’s an easy process which can be done with the cab’s in situ.
- I had a flat spot at around 4k rpm and this solved the issue.
