Jan 9, 2023 at 7:24 PM
#9414
It’s time someone designed and made a new one that can be fitted after carbs. Come on engineers, someone make one!
You can technically do it like this;
- CNC BOX made out of metal.
- 48mm(ish) rubber slots (from some other bike you hunt at salvage yard) under the metal box with 2 holes.
- Carb sits on the metal box
- Front of the metal box has cnc welded metal pipe with a short rubber boot to hang on to the side-right air filter container.
Then you can do away with the complicated plastic box 🙂
That’s why my tutorial advises the plastic box and carbs to mount first and tight….. the slide intake pipes from under 1 by 1 , i mean if you do it often it becomes easy and routine like.
The stress comes from being delicate with the rubber pipes that can easily buldge and split!
