Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Gravity fed fuel Reply To: Gravity fed fuel
Jan 4, 2023 at 8:54 PM
#9352
If you have a comet that has ON/OFF tap (Silver Frame type) = Just clean it out well as it does its job quite well. When its OFF, there is zero chance of hydrolocking the engine anyways
As dodgy pumps can STILL allow fuel to the carbs if the tap is left on the ON position.
If the frame is black and tap is “Vacuum” type = Disconnect fuel hose (safely!!!) , if it pours out while the bike is switched off = Just replace it.
