Dec 28, 2022 at 4:38 PM
#9299
OK! I decided to do a more exhaustive check (no pun intended!) and after starting I let it run for a bit to get exhausts warm. Front warm, rear COLD! I have a spark so must be carb or airflow. So I’ve pulled the carbs off (easier 2nd time!). The stub seals were perfectly fine, so I’ve stripped the carbs again and thoroughly cleaned and blown through. In the kits you sent there were 4 seals as per picture, and I don’t know where they should go. Can you tell me? Should there be anything on the idle jets? And what are the brass bits arrowed? How can they be cleaned internally?
Happy hols!
