Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Drive Chain Adjustment – GT250 EFi Reply To: Drive Chain Adjustment – GT250 EFi
Dec 19, 2022 at 8:38 PM
#9262
Thank you for your advice. I will check alignment according to your method over the next few days. One point… you say slack has to be 15mm but the Hyosung manual recommends 30mm!!!
15mm when the bike is in the air (resting on paddock stands), it means the suspension has compressed, so the chain slack reduces.
When the bike has both wheels on the ground and on its side-kick stand , it should be 30mm like most motorcycles 🙂
I will say always check the slack again once its on the ground after tightening things up & dropping the bike down gently away from its paddock stands.
if i made any sense 😀
