Nov 21, 2022 at 4:44 PM
#9104
Thanks Marcel. I know you have mentioned Blue coloured web sites in other posts, but I have been looking at hyosungcatalog.com and they say they are supplying original parts directly from Hyosung Korea. Any thoughts on that? Their parts list shows a different part number for front and rear needle jet. Are they therefore different sizes? Can you supply the front one with the securing “acorn” bolt, and the 92.5 and 95 main jets? Your carb overhaul kit doesn’t show the moving fuel valve bits, I assume they come with the bodies?
Lastly you mention altering the idle screws. I am not changing the plugs or leads at the moment (need to make sure I can start the bike first!), so does your suggestion still hold?
