Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Lost keys, need advice Reply To: Lost keys, need advice
Nov 6, 2022 at 8:01 PM
#9009
If you find a spare key, send a DM to me and ill post a blank that you can go to keycutters to copy. Otherwise, you have to change barrel and fuel cap. DM me again as i have a used barrel & fuel cap with one key going for cheaps. no used pillion lock as i sold it sadly.
Still got the blanks mate? Can I dm you?
I am not sure but i can probably find out ?
Otherwise, please check out your local Morrisons or Sainsbury’s they should have a stall called Timsons Keys , and tell them you want to copy a Hyuindai Key (which the Hyosung is based off on if i remember correctly) if in a rush.
