Forums 🚥 PiT STOP 🔧 Hyosung Technical Help No spark – GT250 Carby Reply To: No spark – GT250 Carby
Jul 26, 2022 at 8:28 PM
#8196
What is missing from the manual…the correct pin-out for CDi, with correct wiring-colors…
Just quick-tested my wiring, and found that the BROWN wire had 0-ohm to gnd/chassi with support up, infinite, with support down. Clutch-switch also had an impact.
Could not get a reasonable reading thru pickup, shows several M-ohm ???(Green to Blue), (Green to gnd ~100 ohm…) ?
(Runs OK) !
Arne K
2017 GT-R-125
Old and grumpy,(?), have fairly wide engine & tuning experience, "restoring/resto-mod" on cars & mc, worked as electronic tech. (retired).
GT125R - sold. New (used): GT250R-efi + GV-125C
