Oct 26, 2021 at 9:59 PM
#6516
This may sound stupid but what fuel are you using? If its e10 the higher ethonol content can cause all sorts of problems. The oil leak from the rubber is nothing to worry about as a general rule it could just be a slightly loose bolt or the rubber has perished not a hard fix.
