Sep 26, 2021 at 9:19 AM
#6315
Yep, similar issue with me. Its something to do with the clutch, been riding like that for years and nothing terrible has happened. It only occurs at low revs/idle, in neutral when the clutch is disengaged. The second you pull in the clutch, the noise goes away. I was told by a garage that it was just regular clutch rattle/noise, and it has not been a problem since (with failing MOTs/servicing). It hasn’t affected performance either.
this is a different noise and a different problem and is caused by either the clutch release bearing or faulty or unevenly tentioned clutch springs
