Hey,
It should be 85 FT LBS  for rear axle wheel bolt
Front wheel spindle bolt should be a 12mm Allen Key Bit and torque it up to 60 FT LBS  (ish)
Then ofcourse tighten the little bolt thats on the right handside of the fork under neath which stops the front wheel spindle from spinning / anti-vibration.
Use Google to convert  FT LBS to N.M if you torque wrench uses NM instead of Ft.Lbs
