Peadar
  • Topics: 6
If you raise and support the bike with the rear wheel off the ground and try to move the swinger arm left to right. If there is movement then the roller bearings need replacing. If no movement on swingarm try twisting rear wheel. If there is movement then the problem is likely to be either worn bearings or more likely worn cush drive rubbers.
