May 8, 2021 at 4:36 PM
#5828
No go on popping It back in im afraid. I removed the clutch cover so i could get a peek through the holes at the gears while i turned the wheel and the missus jiggled the gear lever. Nothing seemed to be moving other than one Cog on the far side. Im now trying to remove the engine to take It to a proper mechanic, but, i have been scuppered again. One fastener on each of the exhaust pipes is an elongated nut the other is what appears to be a rivet. Is this right as It would seen a lot if buggering about just to get an exhaust off? Once again thankyou in advance For any info.
