Sorry Luke you will have to take them off again 😔 You have to turn the carb’s so that the float’s are pointing upwards and the float is just resting on the needle valve, measure the height from the top edge of the body to the top float, the measurement should be 7mm.
I have just checked the GV125 Service Manual. It says the float height should be 17mm. It’s currently at 7mm. Is this correct?
Koreans should be more clear.
17mm = when carb is sitting on bike manifolds.
7mm = upside down on the table. 🙂
