I have finally found the time to strip and rebuild the carbs. Carb rebuild kit installed. Float height 7mm. Everything looks good. I have got an “Updated & Braided Air/Vacuum Intake Line Hose Kit” from Marcel. Only problem is the photos on the website are unclear as to where the new lines go. I have only got one connection to the fuel tap, the photos show two. I am guessing the other one is the fuel tank vacuum? Does one go to the two inlet manifolds? Help would be greatly appreciated Luke
Because its a GV125.
Both manifolds join with a T-Piece junction and they feed only the fuel pump.
The tap on GV125 doesnt use vacuum as its manual ON/OFF 🙂
