Apr 7, 2021 at 11:53 AM
#5684
Sorry Luke you will have to take them off again
You have to turn the carbโs so that the floatโs are pointing upwards and the float is just resting on the needle valve, measure the height from the top edge of the body to the top float, the measurement should be 7mm.
I have just checked the GV125 Service Manual. It says the float height should be 17mm. It’s currently at 7mm. Is this correct?
