Leon
šŸ‘¤ Member
  • Topics: 0
Hi Chris, Any luck with this? With the run(red) switch on, turn the key on and off three times, then count the flashing sequence of the FI light. Post it here when you have it, You can also find this info in the service manual. Cheers Chris.
Hi, I’m new to this forum. I have the same issue. I did as you suggested. The number sequence I got was 10-8-5 and then back to 10. How do I find out what this means?
