#5020
Alan McLean
Member
  • Topics: 11
@macker
Orihuela Spain
Aquila GV125
Hi Marcel, I’ve only got a chance today to have a look at the bike, but I found what the main problem was, it was only firing on the front cylinder! The problem was a simple one, the spade connector on the coil for the rear cylinder had fallen off, it was a very loose fit so I just squeezed it with a pliers. I wish they were all as simple as that 🤣
However even though the bike is running so much better it has a flat spot between 4k and 5k rpm, any Idea as to what could be causing this. !!!
