Sep 24, 2020 at 7:26 PM
#4903
It means time to change:
- Barrel , Piston with Rings , Tensioner
And likely also:
- Check valves aint bent.
- Cam chain isnt worn down or replace it ideally
- Change tappet numbers (WHEN you do timings and clearances , *must be done* )
As with new parts, run it in for few hundred miles.
