Jun 1, 2020 at 8:00 PM
#4518
Is the engine turning over? If it is & its not starting its a fueling problem disconnect the relays give them a clean put them back in, the fact it’s not starting does say to me that it’s a pump problem, if the other systems are wrong it should still start admittedly it could be rough but should do something. You can enter a mode that will tell you what has failed but I’m not sure how on the gv650.
