Simon
  • Topics: 1
Have you joined the wires together? Is your battery draining? The f1 light is to do with the fueling/ignition electronics so the switch should not be causing that. If your charging system has gone up the wall it can cause all sorts of gremlins, the clicking will be a relay messing about that could be the cause most likely the fuel pump one.
