May 25, 2020 at 2:21 PM
#4454
I wouldn’t have thought you have a bent/damaged valve this would cause issues whether hot or cold, the losing power etc when hot could be a fueling problem check the intake manifold for leaks. A headgasket could do the same a simple compression test would be the quickest way to rule that out.
