Hi Josh’s dad here . Problem we have is there is no ignition or dash lights , no horn or lights ect nothing on starter button? It turns over as normal if cross starter solenoid, took off and sprayed every connector I can see including the fused one under back seat ? Any help would be very much appreciated b4 I break lockdown and push it off a cliff !
Bloody hell, that’s a poorly machine, if you can’t see the dashboard turn on. We must inspect the harness..
So,
- Go to rear pillion seat, confirm the fuse is still intact and 15A?
- Disconnect the regulator/rectifier on the left frame (temporarily!)
- Lift the tank, and “click this blue link here” ….
Only follow #1 – #6 on how to remove the airbox. - Now look for these plugs:
GREEN BLOCK = Ignition barrel (crucial)
BLACK BLOCK = Kill Switch unit / right SW gear.
BLUE BLOCK = Dashboard harness.
Also, please confirm the GREEN BLOCK has 12.8v going to the ignition barrel (no less)
Also last thing, confirm when the key turns – Do the “headlights” come on ? The bike’s headlights will always come on upon key turning.
The “NEUTRAL” light LED will also come on (even if the LCD glass is turned off, which i hope not as that’s a circuit failure potentially or a damaged harness / shorted somehow)
So please advise on what you did as above and report your progress …
