So the pipe on the right side is in the right side of carb top pip is with yellow clip is vacum line i bleave its hooked up now i have 3 pipes one off the left side of the carbs the bottom pip with the fule filter on the pump then i my fule tap that has 2 pipes out one on top and my fule thank has 2 out fule lines and the other hole i guess is the breather
