Oct 1, 2019 at 4:12 PM
#3316
Lets see if we can get the technical specs of the parts you had , before we troubleshoot, i know some stators don’t mix on every hyosung.
So if you have a 2010 bike, can i ask?
- Is the ECU “daewoo” or “sentec”? (incase of a late switch over in 2009/2010, efi began in 08) but for sure 2012+ is delphi otherwise just let us know the ecu’s part number and ill match up the harness , stators , regs it uses.
- Was the reg a genuine hyosung one? (i wouldn’t keep this thing forever, since 9/10 of us upgrade to better mosfet ones than basic shunt regulators hyosung makes)
- What part number is the STATOR you bought? (or check purchase reciepts) (cruicial)
(some flywheels of certain hyosungs want specific stators, as ive seen first hand of no crank issues or sometimes not charging as flywheel wasnt responding the stator coils to produce juice)
