Forums 🚥 PiT STOP 🔧 Hyosung Technical Help No spark gt125r 06 Reply To: No spark gt125r 06
Ok so the mixture screw is already set at 3 turns out as when the bike ran before this issue it was perfect mixture, ill pull the carb out and the intake pipes and give em a clean again and send pics, airbox is intact, when the bike runs the tap does release fuel in a small stream, but when tank is disconnected it drips. (when full choke it streams fuel). Now thinking about it if air is restricted (as in not enough air in engine) it would cut out similar to how it did, would the bike run without the air box?, bike is in shed rn, but i heard that dosnt really effect the bike running, the carb slides could effect air intake, its either got less air or less fuel, one of the 2, my rear spark plug the center is white and this was the time when the engine starved fuel.. ill check the front one to see is thats changed.
