Forums 🚦 HYOSUNG CULTURE 📸 Pictures & Projects GV125c Aquila single seat conversion & rack Reply To: GV125c Aquila single seat conversion & rack
Hi Alan,
Background for you. First one I ordered didn’t fit, so after further measuring the second one was okay. Both from Amazon, so I could send back. Mine came from TOPRAMETAL, but it says unavailable. Below is a photo of the dimensions for mine and I’ve found one similar, search for b0dmjgcgs5 and it should be the third item down. The dimensions are really close.
Please note I was playing around working out what to do and I cut away part of the rack for it to go around the original fixing points, but then I didn’t like the finish, so took the rubber grommets out and used bolts and nuts with washers to make new holes through the fender. If you choose that method you don’t need to cut the front section away.
Hope that makes sense.
