Forums 🚥 PiT STOP 🔧 Hyosung Technical Help gv125s 2022 Cutting out when going into gear Reply To: gv125s 2022 Cutting out when going into gear
Nov 22, 2024 at 6:22 PM
#15572
Hey glad you sorted that out, be sure to remove it and apply “contact” cleaner on it and make sure the “plug” is out of sight so that the front tyre doesnt chuck so much water at it.
Then use grease on the actual kickstand & it’s attached switch down there so that it doesn’t seize up since it moves all the time (stand down, stand up, stand down, etc…)
