Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Gt250 almost no compression Reply To: Gt250 almost no compression
Nov 12, 2024 at 1:37 AM
#15506
Today I found out it’s shim under bucket 🙁 never done those before. Is there a service manual on here for a 2008 gt250r? (Not sure where to look) Online I have only found partial manuals. I think you were correct on the stuck float thing . I pulled the air filter and there was a puddle of fuel towards the nose . Also, I did plug the egr hole in the airbox and I am going to run vac.from the front cyl boot to the pump directly and rear cyl to the diaphragm on the petcock directly instead of tees. Unless there is a balance issue?
