Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Hyosung gv125 classic wiring Reply To: Hyosung gv125 classic wiring
Oct 23, 2024 at 6:54 PM
#15308
Will need pictures from you and it must be clear for all to see , if a wire is not visible in the picture, then its hard.
Also it helps to mention something like this:
1. Found this plug (with supporting picture)
2. here is the exact wire colours
3. This plug was under the fork = We will tell you it is for a speed sensor etc.
