Forums 🚥 PiT STOP 👨🏭 Tutorials | DIY Diagrams Guides Hyosung GV650 / ST7- Front Drive Pulley Removal without Belt / Chain Tutorial Reply To: Hyosung GV650 / ST7- Front Drive Pulley Removal without Belt / Chain Tutorial
Thanks for the heads-up. Though I’m afraid I may have the opposite problem as I over torqued the front drive sprocket nut but will definitely be keeping an eye on the entire assembly. The X-chain conversion fitted perfectly without any fuss, but I’m still a tad nervous about either of the sprockets coming loose. Not really a fan of chain drive but it is the best option for a GV650 as old as mine. Definitely will go through every last nut and bolt before getting a Stage 1 ECU tune
--==I have come to comfort the disturbed and to disturb the comfortable==--
