Forums 🚥 PiT STOP 🔧 Hyosung Technical Help GV650 – IGNITION INTERLOCK SYSTEM ERROR Reply To: GV650 – IGNITION INTERLOCK SYSTEM ERROR
Jun 14, 2024 at 9:52 PM
#13757
Have you replaced the starter motor solenoid then ?
Also , try to do a continuity test on all wires to make sure nothing is shorted / broken circuit somewhere relating to the starting solenoid and the O wire as O wires tend to be live when the bike is ON.
If you see burn marks, post some pictures up 🙂
