Reiss
Post above isn’t great, writing on mobile so apologies in advance.
So the issues I’ve identified so far:
– Can’t start without full choke.
– Can’t idle without throttle held at around 1-2k RPMs when choke is off.
– Battery isn’t charging whilst riding.
– Fuel indicator constantly flashing empty, even when tank is filled.
– Bogging/Sluggish acceleration, doesn’t sound healthy.
– Rubber inlets are worn, small cracks visible but only seems to be surface level. They’re 7 years old, so not surprised.
What I’m considering:
1. Remove carbs & give them a proper clean out & make sure everything is in order.
2. Upgrade the regulator with the one from the shop.
3. Replace rubber inlets with custom-made metal ones.
4. Upgrade stator with shop one. (Will have to purchase this following payday, as money is tight.)
5. Swap out plugs & caps with NGKs as recommended, along with iridium spark plugs.
This forum has a wealth of knowledge and I do appreciate the wizards behind it, but would love some additional support.
Have I missed anything? And how would I remedy a dodgy fuel level read on the dash?
If anyone is based in the Midlands and could give me hand, I’ll be happy to sort you out.
Cheers,
RJ
