Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Hyosung GD250R Front Sprocket seal replacement. Reply To: Hyosung GD250R Front Sprocket seal replacement.
Hey guys, just wanted to know if anyone knows the part number for the front sprocket seal replacement for the Hyosung GD250R. Haven’t been able to find it on Ebay or other sites like whygostock. I’m sure that the replacement is on the Hyosung manufacturer’s website but I have no clue what is the part number. Or does anyone know the exact size so I can get a knock off one from ebay. Please let me know. Thanks!
For the GD250 EXIV models = Suzuki OIL SEAL, LH (27X40X6) The size is in the brackets 🙂
Make sure you check the O-Ring that’s inside the COLLAR SPACER SHAFT too, and use any local hardware store to get a 1-to-1 copy in VITON grade as it gets very hot down there too.
