Forums 🚥 PiT STOP 🔧 Hyosung Technical Help 2010 GV250 EFI missfire Reply To: 2010 GV250 EFI missfire
Hey welcome!
Have you tried these ?
- Go to airbox or the frame look for a device that has wires going to it in one side , then other side has 2 pipes sending air around the motor and throttle bodies
That’s your IDLE SPEED CONTROL VALVE
If its haywire , it could be the reason. - Ignition coils = Did you swap around ?
- HT leads = Did you swap them around ?
I have a suspicion it’s something to do with wires near the rear cylinder (connector plug corrosion on rear cylinder ? or the coil ? or HT Cap itself (use NGK) ,
Sounds silly, but please slowly remove the ECU from the harness and carefully use “AIR DUSTER” only and blow out any debris that might enter in to it.
Also use a “SMALL AMOUNT” of – CONTACT CLEANER – on the ECU pins and it’s giant plug – It is a very very difficult part to buy as Korea stopped making them.
Wait overnight to fully dry out, as you don’t want to start the bike and fry the ecu if its pins are still wet.
This might improve signals going to the sensors in the bike to make it run properly.
what waiting for the ECU to dry out, clean the rest of your harness connectors involved and possibly the sensors if there is a suspicious of debris invasion in them or rust / oxidization of pins.
