JP-Hyorider
  • Topics: 2
Nice to meet you from Japan. I’m also struggling with the same issue. And, as Marcel says, failure continues. It’s a difficult task.
I’d like to see that YouTube video. Could you please introduce the URL here?
I will tell you my results.
Regarding the 4p coupler, mine is Daewoo ECU. It seems to be the same. The 2015 GV250 probably does not have a 2P coupler. I think the orange line is 12V, the light blue line is the ECU signal line, and the black and white line is the negative line.
Then I thought it might be an ISO9141 K-Line or SAE J1850 VPW pattern.
Therefore, I ordered a 4P⇒ODB conversion connector from Ukraine that was written to be exclusively for Hyosung. The conversion was orange ⇒ No. 16, light blue ⇒ No. 7, black & white both connected to No. 4 and No. 5.
Unfortunately, I could not connect it to the ECU.
Similarly, my friend’s 2012 Delphi ECU could not establish a connection to the ECU.
lastly.
Some people have had success with past topics on this forum, so I’ll introduce them to you.
GT250 EFI DSpec Stalls at Idle after Warm Up
