Mar 3, 2024 at 8:30 PM
#12487
- Got the bolts of and the big screw but just need to get a puller now , is there a specific size puller or they all a generic size , cheers
I forgot off my head, but is it possible you can measure the bolt size that you took out from the center and find the thread pitch ? β If not i will try to dig through my archives the exact puller tools Hyosung uses themselves. You can also get a βgenericβ big rotor holder for bikes like harley or whatever that allows you to lock the flywheel in place (You will need it to tighten the bolt back in after swapping the starting clutch)
cheers for that ,never been this far into an engine before but thanks to you and vids on YT i am giving it a go ,just got to find a puller .
