Feb 26, 2024 at 7:51 PM
#12406
Before we do that, have you considered that what you are saying so far will mean it’s just the pump and its relay that needs replacing ?
Or you can take the pump out and see if its clogged ?
Fuel Lines = Usually don’t need changing just yet but they are special as they have “blue tabs” you can squeeze to release them off the pump
Then you can lift the tank off , do things slowly , very slowly = They tried to make it easier for us using hoses that have blue tabs (quick release)
Cleaning the injectors is a good idea why not! – Again, its a slow process to remove 1 part by 1 , so you can memorize where everything went , since EFI has more electronic sensors than a carby motor would.
