Forums 🚥 PiT STOP 🔧 Hyosung Technical Help The moment I try to throttle, bike turn dies Reply To: The moment I try to throttle, bike turn dies
Feb 7, 2024 at 7:28 PM
#12275
From the handle bars (left for choke) and (right for throttle) – Remove the cables from the handle bars
Then you can remove your carbs with the cables still attached to their carb.
Now you can see what’s causing them to seize on the table somewhere.
This will protect your “rubber intake” pipes close to engine heads from splitting or getting stress under pressure
